Ga door naar hoofdinhoud
Skytex SP728 Antenna Replacement
Wat je nodig hebt
  1. Skytex SP728 Antenna Replacement, Case: stap 1, afbeelding 1 van 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Antenna Replacement: stap 2, afbeelding 1 van 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Antenna Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Antenna Replacement: stap 4, afbeelding 1 van 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Antenna Replacement, Antenna: stap 5, afbeelding 1 van 1
    • Remove the case and open the device
  6. Skytex SP728 Antenna Replacement: stap 6, afbeelding 1 van 1
    • Remove the black tapes
  7. Skytex SP728 Antenna Replacement: stap 7, afbeelding 1 van 1
    • Use the soldering station and remove soldered connections to the antenna wires.
    • Now replace the antenna.
    • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Galika Adhikari
248 Reputatie
2 handleidingen geschreven
USF Tampa, Team 5-1, Brown Winter 2015 Lid van USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 100
