Ga door naar hoofdinhoud
Sky Thunder HD 8500WH Lower and Upper Body Replacement
Wat je nodig hebt
  1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: stap 1, afbeelding 1 van 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: stap 1, afbeelding 2 van 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: stap 1, afbeelding 3 van 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: stap 2, afbeelding 1 van 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: stap 2, afbeelding 2 van 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: stap 3, afbeelding 1 van 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: stap 3, afbeelding 2 van 3 Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: stap 3, afbeelding 3 van 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Lower and Upper Body Replacement: stap 4, afbeelding 1 van 2 Sky Thunder HD 8500WH Lower and Upper Body Replacement: stap 4, afbeelding 2 van 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 140
