Ga door naar hoofdinhoud
Sky 6.0Q Top Motherboard Replacement
Wat je nodig hebt
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: stap 1, afbeelding 1 van 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: stap 2, afbeelding 1 van 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: stap 3, afbeelding 1 van 2 Sky 6.0Q Top Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: stap 5, afbeelding 1 van 3 Sky 6.0Q Top Motherboard Replacement: stap 5, afbeelding 2 van 3 Sky 6.0Q Top Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Once the screws are removed, gently lift the top motherboard and replace.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Monica Difato
429 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Hovde Fall 2018 Lid van IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 514
