Inleiding
If the device is having poor front camera performance, consider replacing the front camera of the Sky 6.0Q phone. Replacement of the front camera of the device can be needed if the camera is not working, giving blurry or dark images, has lens damage, or if the lens is exposed to water. The design of the Sky 6.0Q phone makes accessing the front camera difficult, so it is necessary to be careful when removing the back plates and to not lose the small screws. It is recommended to use a magnetic work board to keep the screws from rolling away and are always on hand once the camera is replaced. Although removing the front camera is not hazardous, be careful of disrupting other components that could be hazardous while replacing.
Wat je nodig hebt
Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
Pry off the back plate with the spudger.
Één andere persoon heeft deze handleiding voltooid.
