Ga door naar hoofdinhoud
Sky 6.0Q Battery Replacement
Wat je nodig hebt
  1. Sky 6.0Q Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: stap 2, afbeelding 1 van 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: stap 3, afbeelding 1 van 2 Sky 6.0Q Battery Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: stap 5, afbeelding 1 van 1
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: stap 6, afbeelding 1 van 1
    • Once separated, remove battery and replace with a new battery.
Conclusie
Monica Difato
429 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Hovde Fall 2018 Lid van IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 2,337
