Ga door naar hoofdinhoud
Skullcandy Lowrider Wiring Repair
Wat je nodig hebt
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: stap 1, afbeelding 1 van 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: stap 1, afbeelding 2 van 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: stap 1, afbeelding 3 van 3
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: stap 2, afbeelding 1 van 2 Skullcandy Lowrider Wiring Repair: stap 2, afbeelding 2 van 2
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: stap 3, afbeelding 1 van 3 Skullcandy Lowrider Wiring Repair: stap 3, afbeelding 2 van 3 Skullcandy Lowrider Wiring Repair: stap 3, afbeelding 3 van 3
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: stap 4, afbeelding 1 van 1
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
Conclusie
Ryley
273 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 632
