Ga door naar hoofdinhoud
Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
Wat je nodig hebt
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: stap 1, afbeelding 1 van 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: stap 2, afbeelding 1 van 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: stap 2, afbeelding 2 van 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: stap 2, afbeelding 3 van 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sean
282 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-3, Blackwell Fall 2014 Lid van USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Leden
9 handleidingen geschreven
5 opmerkingen
my battery is stuck in the drill any ideas
yonko99 - Antwoord
My battery is also stuck. I see no replies. What now?
Bobby Verdier - Antwoord
Thank you, it really was easy !!!!!
Betty - Antwoord
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - Antwoord
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 78
Altijd: 6,154
