Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With a 13mm wrench, remove the axle nut located in the center of the wheel.
Set the axle nut aside, and remove the wheel.
Position the wheel at the end of the axle.
To remove the bearings, gently pry the wheel at a downward angle.
Perform this prying process on both sides of the wheel.
Position the new wheel on a flat surface.
Press the bearing into the hole of the new wheel.
Flip the wheel over.
Insert the bearing spacer into the back the wheel.
Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
Slide the second washer onto the axle on the outside of the wheel.
Tighten the axle nut firmly.
Repeat steps 1-9 for the remaining wheels.
9 andere personen hebben deze handleiding voltooid.
3 opmerkingen
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
