Inleiding
Is your skateboard veering off in the wrong direction or are you not going in a straight path? Then it’s time to replace the hanger of your skateboard. This guide will teach you how to disassemble & replace a skateboard hanger if it's damaged or broken.
Wat je nodig hebt
Using the T-tool, unscrew the nut securing the wheel and remove it, setting it and the wheel aside.
Bijna klaar!
Conclusie
