Ga door naar hoofdinhoud
SiriusXM Onyx Plus Motherboard Replacement
Wat je nodig hebt
  1. SiriusXM Onyx Plus Motherboard Replacement, Case: stap 1, afbeelding 1 van 1
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Motherboard Replacement: stap 2, afbeelding 1 van 3 SiriusXM Onyx Plus Motherboard Replacement: stap 2, afbeelding 2 van 3 SiriusXM Onyx Plus Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Once unclipped, separate the back casing from the device.
  4. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 SiriusXM Onyx Plus Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the three 5.4mm JIS #00 screws from the motherboard.
  5. SiriusXM Onyx Plus Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Unlatch the two clips located at the top of the device that hold the motherboard in place.
  6. SiriusXM Onyx Plus Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the motherboard up from the bottom.
  7. SiriusXM Onyx Plus Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Lift the screen up, so you can see where it is attached to the motherboard.
  8. SiriusXM Onyx Plus Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  9. SiriusXM Onyx Plus Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Carefully pull the ribbon out from the ZIF connector.
Conclusie
Angel Rivera
532 Reputatie
5 handleidingen geschreven
USF Tampa, Team S7-G2, Passmore Spring 2018 Lid van USF Tampa, Team S7-G2, Passmore Spring 2018
USFT-PASSMORE-S18S7G2
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 1,772
