Ga door naar hoofdinhoud
Singular Cylinder Kwikset Deadbolt Replacement
Wat je nodig hebt
  1. Singular Cylinder Kwikset Deadbolt Replacement, Singular Cylinder Kwikset Deadbolt: stap 1, afbeelding 1 van 1
    • Turn the lock clockwise until two screws are visible.
  2. Singular Cylinder Kwikset Deadbolt Replacement: stap 2, afbeelding 1 van 1
    • Remove both screws from the lock cylinder using a Phillips #3 screwdriver.
  3. Singular Cylinder Kwikset Deadbolt Replacement: stap 3, afbeelding 1 van 1
    • Remove the lock cylinder from the door.
  4. Singular Cylinder Kwikset Deadbolt Replacement: stap 4, afbeelding 1 van 1
    • Remove the pin and key cylinder from both of the secondary and primary support cylinders.
  5. Singular Cylinder Kwikset Deadbolt Replacement: stap 5, afbeelding 1 van 1
    • Remove the secondary support cylinder from the primary support cylinder.
  6. Singular Cylinder Kwikset Deadbolt Replacement: stap 6, afbeelding 1 van 1
    • Remove the primary cylinder support from the door.
  7. Singular Cylinder Kwikset Deadbolt Replacement: stap 7, afbeelding 1 van 1
    • Remove both of the 3/4 inch screws from the face of the latch mechanism using a Phillips #3 screwdriver.
  8. Singular Cylinder Kwikset Deadbolt Replacement: stap 8, afbeelding 1 van 1
    • Remove the latch mechanism with the latch face from the door.
  9. Singular Cylinder Kwikset Deadbolt Replacement: stap 9, afbeelding 1 van 1
    • Insert the new latch mechanism with the latch face in the door. A capital letter "A" should face upward in the latch face.
  10. Singular Cylinder Kwikset Deadbolt Replacement: stap 10, afbeelding 1 van 1
    • Reinsert both of the screws in the latch face using a Phillips #3 screwdriver.
  11. Singular Cylinder Kwikset Deadbolt Replacement: stap 11, afbeelding 1 van 1
    • Insert the primary support cylinder in the door.
  12. Singular Cylinder Kwikset Deadbolt Replacement: stap 12, afbeelding 1 van 1
    • Insert the secondary support cylinder in the door.
  13. Singular Cylinder Kwikset Deadbolt Replacement: stap 13, afbeelding 1 van 1
    • Insert the new pin and key cylinder in both the primary and secondary support cylinders.
  14. Singular Cylinder Kwikset Deadbolt Replacement: stap 14, afbeelding 1 van 1
    • Insert the new lock cylinder in the door by aligning the lock with the pin of the key cylinder.
  15. Singular Cylinder Kwikset Deadbolt Replacement: stap 15, afbeelding 1 van 1
    • Insert both of the screws in the lock cylinder using a Phillips #3 screwdriver.
Conclusie
Please follow the link listed to purchase the singular cylinder kwikset deadbolt package or type in Google “singular cylinder kwikset deadbolt” to find the appropriate parts, if not interested to purchase from the link listed.
Jules Torilus
241 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 76
Altijd: 1,150
