Inleiding
If your Singing Machine Shine Duets karaoke machine's LED lights are not functioning on one or more sides, access the LED board and motherboard by following our guide. Because the LED board needs to be connected to the device by pins and a screw, you will need to attach/reattach it using our guide. This repair is not particularly difficult, but it will require some relatively forceful part separation, so be careful and methodical.
Wat je nodig hebt
Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
