Inleiding
This is a quick tutorial on how to replace the brass bushing by Bearing.
Wat je nodig hebt
Just push or pull the middle tube then push the bushing out.
Add the bearing into the hole flange facing "outside".
Add a M5 1mm washing on the bearing, on the flanged part (facing outside).
Just place the spring back into place. You may use a little flat screw driver for help.
4 andere personen hebben deze handleiding voltooid.
10 opmerkingen
Washers need to be 1mm or 0,1mm ? https://www.loziska-rc.com/85440090?sear... will these be good?
1mm exactly, that's about the space left between the bearing and the plate.
edit : Yes those should be fine.
Hi,
You mention F605ZZ (14x5x4mm) but all F605ZZ I find are 14x5x5mm.
Are you sure yours are 4mm wide ?
Thanks in advance and excellent idea and guide by the way !
they are indeed 5mm wide, my bad. I will correct the post !
