Ga door naar hoofdinhoud
Sigrow Soil Pro Assembly
Wat je nodig hebt
  1. Sigrow Soil Pro Assembly, Ensure you have the components: stap 1, afbeelding 1 van 1
    • Watermelon Soil Sensor
    • b07 PCB [coated]
    • body b07
    • hat b07
    • inside bottom plate b07
    • You will need a flat-head screw driver (1.5 to 2.0 mm)
  2. Sigrow Soil Pro Assembly, Insertion cable: stap 2, afbeelding 1 van 2 Sigrow Soil Pro Assembly, Insertion cable: stap 2, afbeelding 2 van 2
    • Insert watermelon cable through case and inside bottom plate
    • Pay attention that the temperature humidity sensor slot is on the left side
  3. Sigrow Soil Pro Assembly, Connect soil sensor to pcb: stap 3, afbeelding 1 van 2 Sigrow Soil Pro Assembly, Connect soil sensor to pcb: stap 3, afbeelding 2 van 2
    • Ensure all the ports of the connector are open
    • These 4 ports are open!
    • This port is closed!
    • To open the port unscrew counterclockwise
    • Follow the colour guideline and ensure all the cables are fully inserted.
    • Close the ports tightly by rotating clockwise. One at a time is easier.
  4. Sigrow Soil Pro Assembly, Slide pcb in: stap 4, afbeelding 1 van 3 Sigrow Soil Pro Assembly, Slide pcb in: stap 4, afbeelding 2 van 3 Sigrow Soil Pro Assembly, Slide pcb in: stap 4, afbeelding 3 van 3
    • Ensure 8 to 12 cm of cable are left inside the case facing upwards
    • Slide pcb in.
    • Quality Control: If the PCB doesn't slide in the case or the fit is too loose (PCB slides downwards by itself when inverted) OR the pcb makes a shaki sound when you shake the case -> request new case or contact a senior sigrow technician
  5. Sigrow Soil Pro Assembly, Close the case with hat: stap 5, afbeelding 1 van 2 Sigrow Soil Pro Assembly, Close the case with hat: stap 5, afbeelding 2 van 2
    • Quality Control: Looks easy but the hat shouldn't be too tight (no need to force to insert it) and not too loose (doesn't fall when sensor upside down)
  6. Sigrow Soil Pro Assembly, Place in inventory box: stap 6, afbeelding 1 van 1
    • Boxes of 10, sensors on borders, cables towards the center so we can pull them easily later
Conclusie
In case of doubt reach a senior sigrow technician
Één andere persoon heeft deze handleiding voltooid.
Sigrow
1.075 Reputatie
5 handleidingen geschreven
Sigrow Lid van Sigrow
Community
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 203
