Ga door naar hoofdinhoud
Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Filter for Gas Modules: stap 1, afbeelding 1 van 1
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: stap 2, afbeelding 1 van 1
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: stap 3, afbeelding 1 van 1
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: stap 4, afbeelding 1 van 1
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Pressure Transducer Filter: stap 5, afbeelding 1 van 1
    • Replace plastic nozzle units in the gas modules.
    • After replacement of plastic nozzle units, wait 10 minutes before connecting pressure to the gas modules
    • Service Manual 7 - 4
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Maria Brown
196 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Lid van Cal Poly, Team S1-G2, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G2
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 484
