Inleiding
Replacement of the Pump/Floater switch of the condensation water tank of the Siemens Siwatherm 7400 Series IQ
After removing the side cover (if you are standing in front of it on the right) the motor of the drum becomes visible. The pump of the condensation water tank and the float are located directly underneath. The drive tensioner must be loosened for removal/exchange.
Remove all plugs from the drive (not shown in the picture!) and remove the placeholder. Unlock the lock with your thumb.
Remove the cable from the float and the pump and pull off the hose at the back. The motor can be folded upwards.
Once the cover is removed, the pump and float can be easily removed.
In this step, the tank should be cleaned to prevent the pump from clogging up quickly.
The rear part of the container can be reached from the other side. Remove the left side panel and pull out the condenser to the front.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Één opmerking
Danke vielmals für die Hilfestellung. Ohne das Entfernen der Motorhalterung hatte ich die Abdeckung zunächst nicht rausbekommen. Das Hauptproblem war aber dies. Siehe mein Beitrag :
