Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press down on the grooved area firmly in the direction of arrow #1.
While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
Press the latch on the battery in the direction of arrow #3.
Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
With the phone turned onto its backside, gently slide the metal clasp up to unlock the SIM card.
The SIM card will spring up once the clasp is released.
Remove the SIM card from phone.
To replace the SIM card, insert the card back into the slot.
While pressing the SIM card with one finger, slide the metal clasp down to lock the card in place.
Één andere persoon heeft deze handleiding voltooid.
