Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
After testing other solutions for a malfunctioning screen, replacement of the LCD screen may be necessary. This guide will show the user how to open the Siemens A56 cell phone and remove the LCD screen. If a pixel is not displaying or the screen in general is not displaying, this guide may be a solution.
Wat je nodig hebt
Press down on the grooved area firmly in the direction of arrow #1.
While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
Pull up on the two plastic clips at the top of the phone.
While the clips are pulled up, pull the blue cover away from the white casing to remove it.
Along the side of the metal frame of the phone, locate the six screws.
Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
Once loosened, the metal frame should be able to be lifted from the motherboard.
Insert the fine-tipped spudger in between the motherboard and the keypad interface.
Gently work the spudger across the length of the motherboard.
Once loosened, the motherboard should easily separate from the keypad interface.
Locate the LCD Display.
Above the display, there are two metal clasps. Bend the clasps until they are straight.
