Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
After testing other solutions for a malfunctioning screen, replacement of the LCD screen may be necessary. This guide will show the user how to open the Siemens A56 cell phone and remove the LCD screen. If a pixel is not displaying or the screen in general is not displaying, this guide may be a solution.
  1. Press down on the grooved area firmly in the direction of arrow #1.
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Turn off the phone before removing the battery to avoid damage.
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture. Pull up on the two plastic clips at the top of the phone. While the clips are pulled up, pull the blue cover away from the white casing to remove it.
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Along the side of the metal frame of the phone, locate the six screws. Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place. The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  5. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. To remove the back plastic cover, grasp the device with both hands as seen in the first picture. Gently remove the motherboard from the back plastic cover. The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  7. Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame. Once loosened, the metal frame should be able to be lifted from the motherboard. Once loosened, the metal frame should be able to be lifted from the motherboard.
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
  8. Insert the fine-tipped spudger in between the motherboard and the keypad interface. Gently work the spudger across the length  of the motherboard. An adhesive exists between the motherboard and the keypad interface.
    • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
    • Gently work the spudger across the length of the motherboard.
    • An adhesive exists between the motherboard and the keypad interface.
    • Once loosened, the motherboard should easily separate from the keypad interface.
  9. Locate the LCD Display. Above the display, there are two metal clasps.  Bend the clasps until they are straight. Above the display, there are two metal clasps.  Bend the clasps until they are straight.
    • Locate the LCD Display.
    • Above the display, there are two metal clasps. Bend the clasps until they are straight.
  10. On the sides of the display there are two more metal clasps. Gently bend the clasp so that the metal display frame becomes loose from the screen. Flip the device over and gently bend the other  clasp so that the metal display frame becomes loose from the screen.
    • On the sides of the display there are two more metal clasps.
    • Gently bend the clasp so that the metal display frame becomes loose from the screen.
    • Flip the device over and gently bend the other clasp so that the metal display frame becomes loose from the screen.
  11. Place the device so the display screen is facing up. On the bottom of the display frame, locate two plastic rivets. Remove these rivets by scraping with the plastic opening tool or a fingernail.
    • Place the device so the display screen is facing up.
    • On the bottom of the display frame, locate two plastic rivets.
    • Remove these rivets by scraping with the plastic opening tool or a fingernail.
    • Once removed, the plastic rivets can only be reapplied with a heat gun.
  12. To remove the metal frame, gently grab the frame and lift from the keypad interface. If the frame cannot be easily removed. ensure that the metal clasps from steps 8 and 9 have been sufficiently bent to allow removal. If the frame cannot be easily removed. ensure that the metal clasps from steps 8 and 9 have been sufficiently bent to allow removal.
    • To remove the metal frame, gently grab the frame and lift from the keypad interface.
    • If the frame cannot be easily removed. ensure that the metal clasps from steps 8 and 9 have been sufficiently bent to allow removal.
  13. Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted. Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted. Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted.
    • Once the metal frame is removed, the LCD display should fall from the keypad interface when tilted.
Conclusie
Joseph Casey
409 Reputatie
4 handleidingen geschreven
Clemson, Team 6-6, Benson Spring 2014 Lid van Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Leden
18 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 517
