This step is untranslated. Help translate it
Press down on the grooved area firmly in the direction of arrow #1.
While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
Press the latch on the battery in the direction of arrow #3.
Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
Pull up on the two plastic clips at the top of the phone.
While the clips are pulled up, pull the blue cover away from the white casing to remove it.
The keyboard can be easily removed by hand.
Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
Almost done!
Finish Line
