Ga door naar hoofdinhoud
Siemens A56 Front Plate Replacement
Wat je nodig hebt
  1. Siemens A56 Front Plate Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Front Plate Replacement: stap 2, afbeelding 1 van 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Front Plate Replacement, Front Plate: stap 3, afbeelding 1 van 3 Siemens A56 Front Plate Replacement, Front Plate: stap 3, afbeelding 2 van 3 Siemens A56 Front Plate Replacement, Front Plate: stap 3, afbeelding 3 van 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
Conclusie
Lauren Young
322 Reputatie
3 handleidingen geschreven
Clemson, Team 6-6, Benson Spring 2014 Lid van Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 190
