Ga door naar hoofdinhoud
Sidekick II LCD Screen Replacement
Wat je nodig hebt
  1. Sidekick II LCD Screen Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
    Vraag FixBot
  2. Sidekick II LCD Screen Replacement: stap 2, afbeelding 1 van 2 Sidekick II LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    Vraag FixBot
  3. Sidekick II LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    Vraag FixBot
  4. Sidekick II LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
    Vraag FixBot
  5. Sidekick II LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
    Vraag FixBot
  6. Sidekick II LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 2 Sidekick II LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 2
    • Flip the screen to its up position.
    • Remove screen from keyboard.
    Vraag FixBot
  7. Sidekick II LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove 4 screws from back of screen.
    Vraag FixBot
  8. Sidekick II LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Separate screen from housing with your fingers.
    Vraag FixBot
  9. Sidekick II LCD Screen Replacement: stap 9, afbeelding 1 van 3 Sidekick II LCD Screen Replacement: stap 9, afbeelding 2 van 3 Sidekick II LCD Screen Replacement: stap 9, afbeelding 3 van 3
    • Remove 4 screws
    • Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
    Vraag FixBot
  10. Sidekick II LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove LCD protective cover with your fingers.
    Vraag FixBot
Eindstreep
michael albaum
108 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-19, Maness Winter 2010 Lid van Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 97
Altijd: 4,182
