Inleiding
Taking out the LCD screen.
Onderdelen
Geen onderdelen nodig.
  1. Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  7. Flip the screen to its up position. Remove screen from keyboard.
    • Flip the screen to its up position.
    • Remove screen from keyboard.
  8. Remove 4 screws from back of screen.
    • Remove 4 screws from back of screen.
  9. Separate screen from housing with your fingers.
    • Separate screen from housing with your fingers.
  10. Remove 4 screws Pay attention to the orientation of the screen on the backing because it is difficult to reassemble. Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
    • Remove 4 screws
    • Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
  11. Remove LCD protective cover with your fingers.
    • Remove LCD protective cover with your fingers.
Eindstreep
michael albaum
45 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-19, Maness Winter 2010 Lid van Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Leden
11 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 3,229
