Ga door naar hoofdinhoud
Shure SM58 XLR Microphone Connector Installation Replacement
Wat je nodig hebt
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: stap 1, afbeelding 1 van 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: stap 2, afbeelding 1 van 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: stap 3, afbeelding 1 van 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Conclusie
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 andere personen hebben deze handleiding voltooid.
Ronald Lam
307 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-53, Forte Fall 2012 Lid van Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Leden
20 handleidingen geschreven
7 opmerkingen
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Antwoord
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Antwoord
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Antwoord
Are the threads on your screw stripped?
Daniel Berger - Antwoord
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 10,552
