Inleiding
The XLR connector is the point where the XLR cable is inserted into the microphone. The XLR cable carries the signal to the sound mixer and speakers.
Wat je nodig hebt
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 andere personen hebben deze handleiding voltooid.
7 opmerkingen
Thanks for this. I had a connector where the screw had come loose and the whole assembly had released and become jammed halfway into the housing, with the 3 prongs halfway exposed. I couldn’t quite figure out what was going on with it because it was really bound in there tightly, but your guide helped me sort out what was wrong, remove the connector assembly, and get it reseated properly in the mic housing. Thanks again!
Hi, I am trying to troubleshoot a very old 58, and the xlr connector screw wont stop turning (anti clockwise) and connector still wont come out. What should I try?
The retaining screw at the bottom of the microphone is gone and I am searching for a replacement. What is the specific name of the screw? Thank you!
It’s a grub screw. Just get hold of a Switchcraft Male XLR plug, either new or from an old mic cable, and and remove the screw. Remember the thread is reversed from a normal screw, which is why this is the best way to get a replacement.
Which prong (looking at the bottom of the microphone where the 3 prongs form a triangle Left-Center-Right) is supposed to be connected to the outer shield of the microphone cable (XLR) and which prongs connect to the other two wires running inside the cable?
If you look carefully at the pins they are numbered 1 2 3. The connections are:-
Pin 1 = Shield/Ground
Pin 2 = Red
Pin 3 = Black
If the wires are a different colour, there will usually be one which is black , and if not the mic will still work ok even if the two wires are reversed, it may be out of phase with other mics, but that will not be noticeable in most uses.
Its an old microphone, I'm not the first owner. The screw keeps going infinite and not enough to the connector to come off. What can I do?
nunoandrade - Antwoord
