Ga door naar hoofdinhoud
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: stap 1, afbeelding 1 van 1
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: stap 2, afbeelding 1 van 2 Shure SM58 Grille Replacement: stap 2, afbeelding 2 van 2
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Conclusie
Follow the steps in reverse to install the new grille on the microphone.
5 andere personen hebben deze handleiding voltooid.
nat coll
642 Reputatie
14 handleidingen geschreven
Cal Poly, Team 7-53, Forte Fall 2012 Lid van Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Leden
20 handleidingen geschreven
2 opmerkingen
Can you change the grilles of sm58 and sm86?
Jack - Antwoord
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 43
Altijd: 10,043
