Ga door naar hoofdinhoud
Shower Handle O-ring Replacement
Wat je nodig hebt
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: stap 1, afbeelding 1 van 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
    Vraag FixBot
  2. Shower Handle O-ring  Replacement: stap 2, afbeelding 1 van 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Vraag FixBot
  3. Shower Handle O-ring  Replacement: stap 3, afbeelding 1 van 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    Vraag FixBot
  4. Shower Handle O-ring  Replacement: stap 4, afbeelding 1 van 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
    Vraag FixBot
  5. Shower Handle O-ring  Replacement: stap 5, afbeelding 1 van 2 Shower Handle O-ring  Replacement: stap 5, afbeelding 2 van 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
    Vraag FixBot
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Cori Fitzpatrick
213 Reputatie
1 Handleiding geschreven
4Gids Commentaar
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Antwoord Deel
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - Antwoord Deel
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 202
Altijd: 26,053
