Ga door naar hoofdinhoud
Shortening a Child’s Princess Dress Without Cutting It
Wat je nodig hebt
    1. Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: stap 1, afbeelding 1 van 3 Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: stap 1, afbeelding 2 van 3 Shortening a Child’s Princess Dress Without Cutting It, Shortening a Child’s Princess Dress Without Cutting It: stap 1, afbeelding 3 van 3
      • Have the child put on the too-long dress.
      • Fold the fabric inwards to the desired length.
      • If the dress has multiple layers, you'll have to repeat this entire procedure for each layer.
      Vraag FixBot
      Voeg opmerking toe
    2. Shortening a Child’s Princess Dress Without Cutting It: stap 2, afbeelding 1 van 2 Shortening a Child’s Princess Dress Without Cutting It: stap 2, afbeelding 2 van 2
      • To secure the fabric, place a sewing pin longways into the folded fabric.
      • You should repeat this step with any fabric you want to shorten.
      • Remember, you need to pin one fabric at a time to avoid sewing the layers of fabrics to each other.
      • You need to carefully remove the dress from the child, inserting your hand between the child and the sewing needles when removing so you don't poke the child.
      Vraag FixBot
      Voeg opmerking toe
    3. Shortening a Child’s Princess Dress Without Cutting It: stap 3, afbeelding 1 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 3, afbeelding 2 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 3, afbeelding 3 van 3
      • Lay the dress flat on a neat, stable surface like a table.
      • Fold each fabric layer to identical lengths.
      • After it's the same length, you need to insert sewing pins in the middle or at the edge of the folded fabric, like in the previous step.
      Vraag FixBot
      Voeg opmerking toe
    4. Shortening a Child’s Princess Dress Without Cutting It: stap 4, afbeelding 1 van 2 Shortening a Child’s Princess Dress Without Cutting It: stap 4, afbeelding 2 van 2
      • For the next side (red arrow), fold it inwards to match the length of the original pinned fabric (orange arrow).
      • Insert sewing pins like in Steps 2 and 3.
      Vraag FixBot
      Voeg opmerking toe
    5. Shortening a Child’s Princess Dress Without Cutting It: stap 5, afbeelding 1 van 2 Shortening a Child’s Princess Dress Without Cutting It: stap 5, afbeelding 2 van 2
      • Grab a sewing needle and a thread that matches the color of your fabric.
      • Measure the thread to be the same length as the original pinned fabric, then cut the thread.
      • Insert one end of the thread into the eye of the needle.
      • Leave some length at the top for the next step.
      Vraag FixBot
      Voeg opmerking toe
    6. Shortening a Child’s Princess Dress Without Cutting It: stap 6, afbeelding 1 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 6, afbeelding 2 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 6, afbeelding 3 van 3
      • Thread the needle and knot the thread.
      Vraag FixBot
      Voeg opmerking toe
    7. Shortening a Child’s Princess Dress Without Cutting It: stap 7, afbeelding 1 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 7, afbeelding 2 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 7, afbeelding 3 van 3
      • Insert the needle into the fabric following this motion: down, up, down, up, slight pull out. This creates a circle with the thread.
      • Before the circle ends, you need to pass the needle through the circle, then down into the fabric.
      • You need to pull the thread and needle through all the way.
      • By doing this, you prevent the thread from loosening.
      Vraag FixBot
      Voeg opmerking toe
    8. Shortening a Child’s Princess Dress Without Cutting It: stap 8, afbeelding 1 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 8, afbeelding 2 van 3 Shortening a Child’s Princess Dress Without Cutting It: stap 8, afbeelding 3 van 3
      • Next, you take the needle, insert into the fabric half way then go up, and pull the needle and thread through a little bit.
      • Remember to pull gently so the thread doesn't get knotted.
      • You need to repeat until two-thirds of thread is left or until you get to the start again.
      Vraag FixBot
      Voeg opmerking toe
    9. Shortening a Child’s Princess Dress Without Cutting It: stap 9, afbeelding 1 van 1
      • When there is 2/3 of thread left in the needle, repeat Step 8.
      • After securing it, you need to cut the thread from the needle, closest to where the needle is.
      • You need to remove all of the sewing pins from the fabric you have sowed.
      • For the rest of the fabric or other fabrics, you need to repeat Steps 6-10.
      Vraag FixBot
      Voeg opmerking toe
    10. Shortening a Child’s Princess Dress Without Cutting It: stap 10, afbeelding 1 van 1
      • After you removed the sewing pins, you are finished!
      • Caution: If you leave the sewing pins on the dress, it will hurt the child who wears it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mariana L
181 Reputatie
1 Handleiding geschreven
CSU Sacramento, Team 1-12, Laflen Fall 2024 Lid van CSU Sacramento, Team 1-12, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G12
1 Lid
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 110
Altijd: 879
