Ga door naar hoofdinhoud
Shenzhou k680e Silicone Grease Replacement
Wat je nodig hebt
  1. Shenzhou k680e Silicone Grease Replacement, Silicone Grease: stap 1, afbeelding 1 van 1
    • Place the computer on a table so that its bottom surface is facing you.
  2. Shenzhou k680e Silicone Grease Replacement: stap 2, afbeelding 1 van 1
    • Remove all the screws on the bottom with a screwdriver.
  3. Shenzhou k680e Silicone Grease Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery upwards to remove it from the laptop.
  4. Shenzhou k680e Silicone Grease Replacement: stap 4, afbeelding 1 van 1
    • Pry the back panel away from the laptop using an opening tool.
  5. Shenzhou k680e Silicone Grease Replacement: stap 5, afbeelding 1 van 1
    • Remove the screws from the fan.
    • Detach the fan's wire from the motherboard.
  6. Shenzhou k680e Silicone Grease Replacement: stap 6, afbeelding 1 van 1
    • Remove the fans from the laptop.
  7. Shenzhou k680e Silicone Grease Replacement: stap 7, afbeelding 1 van 1
    • Use a brush or an electric fan to clean the dust on the fans.
    • Don't use your finger to clean it because it may cause permanent damage to the fan.
  8. Shenzhou k680e Silicone Grease Replacement: stap 8, afbeelding 1 van 1
    • Remove the screws from the CPU in the following order according to the index numbers beside the screws: 3, 2, 1.
    • When you reinstall these screws you should follow the order: 1, 2, 3.
  9. Shenzhou k680e Silicone Grease Replacement: stap 9, afbeelding 1 van 2 Shenzhou k680e Silicone Grease Replacement: stap 9, afbeelding 2 van 2
    • Remove the heat sink from the laptop.
    • There is some old thermal paste on the copper section of the heat sink.
  10. Shenzhou k680e Silicone Grease Replacement: stap 10, afbeelding 1 van 1
    • Use an alcohol wipe to clean the thermal paste on the copper sheet.
    • You must use an alcohol wipe since alcohol is volatile and will not stay inside the computer, unlike water.
  11. Shenzhou k680e Silicone Grease Replacement: stap 11, afbeelding 1 van 1
    • Squeeze new thermal paste onto the chips.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Yizhen Qu
217 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 648
