Ga door naar hoofdinhoud
Sharper Image iPulse SI325 Outer Case Replacement
Wat je nodig hebt
  1. Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 2 Sharper Image iPulse SI325 Outer Case Replacement, Outer Case: stap 1, afbeelding 2 van 2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 Outer Case Replacement: stap 2, afbeelding 1 van 3 Sharper Image iPulse SI325 Outer Case Replacement: stap 2, afbeelding 2 van 3 Sharper Image iPulse SI325 Outer Case Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 Outer Case Replacement: stap 3, afbeelding 1 van 2 Sharper Image iPulse SI325 Outer Case Replacement: stap 3, afbeelding 2 van 2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
Conclusie
Melissa Pasa
701 Reputatie
7 handleidingen geschreven
Cal Poly, Team 11-33, Amido Fall 2013 Lid van Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 342
