Ga door naar hoofdinhoud
Sharper Image SVC430 Lens Replacement
Wat je nodig hebt
  1. Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: stap 1, afbeelding 1 van 2 Sharper Image SVC430 Lens Replacement, Sharper Image SVC430 Disassembly: stap 1, afbeelding 2 van 2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Lens Replacement: stap 2, afbeelding 1 van 2 Sharper Image SVC430 Lens Replacement: stap 2, afbeelding 2 van 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Lens Replacement: stap 3, afbeelding 1 van 3 Sharper Image SVC430 Lens Replacement: stap 3, afbeelding 2 van 3 Sharper Image SVC430 Lens Replacement: stap 3, afbeelding 3 van 3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Lens Replacement: stap 4, afbeelding 1 van 2 Sharper Image SVC430 Lens Replacement: stap 4, afbeelding 2 van 2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Lens Replacement: stap 5, afbeelding 1 van 1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Lens Replacement: stap 6, afbeelding 1 van 3 Sharper Image SVC430 Lens Replacement: stap 6, afbeelding 2 van 3 Sharper Image SVC430 Lens Replacement: stap 6, afbeelding 3 van 3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Lens Replacement: stap 7, afbeelding 1 van 1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Lens Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Lens Replacement: stap 9, afbeelding 1 van 1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Lens Replacement: stap 10, afbeelding 1 van 1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Lens Replacement, Lens: stap 11, afbeelding 1 van 1
    • Behind the lens, use the metal screwdriver to unscrew the two screws holding the lens in place on the circuit board.
  12. Sharper Image SVC430 Lens Replacement: stap 12, afbeelding 1 van 1
    • The lens should easily remove from the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 195
