Inleiding
You'll be replacing the keyboard component of the Sharp PC - MM20!
Wat je nodig hebt
First, remove the battery from your laptop and make sure it is powered down.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
Also, remove the flat cable from the track pad to the laptop.
Één andere persoon heeft deze handleiding voltooid.
