Ga door naar hoofdinhoud
Sharp EL-510RN Calculator Battery Replacement
Wat je nodig hebt
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Sharp EL-510RN Calculator Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: stap 2, afbeelding 1 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 2, afbeelding 2 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 2, afbeelding 3 van 3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: stap 3, afbeelding 1 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 3, afbeelding 2 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: stap 4, afbeelding 1 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 4, afbeelding 2 van 3 Sharp EL-510RN Calculator Battery Replacement: stap 4, afbeelding 3 van 3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: stap 5, afbeelding 1 van 1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Conclusie
Harish Kugathasalingam
121 Reputatie
1 Handleiding geschreven
York University, Team 4-5, Allen Fall 2022 Lid van York University, Team 4-5, Allen Fall 2022
YORK-ALLEN-F22S4G5
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 149
