Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Begin by using a nylon spudger to pry off the back.
Remove case around battery using a T5 screwdriver to remove four 5mm silver screws.
Remove two 6mm T5 black screws.
Use the tweezers to remove the pink clips on either side of the device and then take the casing off.
Peel back the grey paper wrapping around the battery.
Use the tweezers to remove the Pancake connector that connects the battery to the phone.
