Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
When doing this action, remember to power down the phone before disconnecting the battery. Also be careful not to completely remove the paper as it helps to keep electrical connections underneath. This repair may be needed if the battery in the phone is found to be faulty.
Onderdelen
Geen onderdelen opgegeven.
  1. Begin by using a nylon spudger to pry off the back.
    • Begin by using a nylon spudger to pry off the back.
  2. Remove case around battery using a T5 screwdriver to remove four 5mm silver screws. Remove two 6mm T5 black screws.
    • Remove case around battery using a T5 screwdriver to remove four 5mm silver screws.
    • Remove two 6mm T5 black screws.
  3. LCD iPhone-scherm fixkits
    De goedkope optie, ondersteund door onze levenslange garantie.
    Koop kits
    Bespaar op reparatiekosten, niet op kwaliteit.
    Koop kits
  4. Use the tweezers to remove the pink clips on either side of the device and then take the casing off.
    • Use the tweezers to remove the pink clips on either side of the device and then take the casing off.
  5. Peel back the grey paper wrapping around the battery.
    • Peel back the grey paper wrapping around the battery.
  6. Use the tweezers to remove the Pancake connector that connects the battery to the phone. Use the tweezers to remove the Pancake connector that connects the battery to the phone.
    • Use the tweezers to remove the Pancake connector that connects the battery to the phone.
Conclusie
Allison Leal
387 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G1, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G1, Peak Fall 2018
UMASSD-PEAK-F18S3G1
3 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 147
