Ga door naar hoofdinhoud
Sharp Aquos LC13B2UA Motherboard Replacement
Wat je nodig hebt
  1. Sharp Aquos LC13B2UA Motherboard Replacement, Stand: stap 1, afbeelding 1 van 2 Sharp Aquos LC13B2UA Motherboard Replacement, Stand: stap 1, afbeelding 2 van 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Motherboard Replacement: stap 2, afbeelding 1 van 2 Sharp Aquos LC13B2UA Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: stap 3, afbeelding 1 van 3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: stap 3, afbeelding 2 van 3 Sharp Aquos LC13B2UA Motherboard Replacement, Back Case: stap 3, afbeelding 3 van 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Motherboard Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos LC13B2UA Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 Sharp Aquos LC13B2UA Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Motherboard Replacement: stap 7, afbeelding 1 van 2 Sharp Aquos LC13B2UA Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Motherboard Replacement: stap 8, afbeelding 1 van 2 Sharp Aquos LC13B2UA Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Conclusie
Robert Hobson
1.290 Reputatie
9 handleidingen geschreven
Cal Poly, Team 1-11, Amido Winter 2011 Lid van Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 7,454
