Ga door naar hoofdinhoud
Sharp Aquos Crystal Rear Camera Replacement
Wat je nodig hebt
  1. Sharp Aquos Crystal Rear Camera Replacement, Back Panel: stap 1, afbeelding 1 van 3 Sharp Aquos Crystal Rear Camera Replacement, Back Panel: stap 1, afbeelding 2 van 3 Sharp Aquos Crystal Rear Camera Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Rear Camera Replacement, USB Port: stap 2, afbeelding 1 van 2 Sharp Aquos Crystal Rear Camera Replacement, USB Port: stap 2, afbeelding 2 van 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Rear Camera Replacement: stap 3, afbeelding 1 van 2 Sharp Aquos Crystal Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Rear Camera Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos Crystal Rear Camera Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Rear Camera Replacement: stap 5, afbeelding 1 van 3 Sharp Aquos Crystal Rear Camera Replacement: stap 5, afbeelding 2 van 3 Sharp Aquos Crystal Rear Camera Replacement: stap 5, afbeelding 3 van 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Rear Camera Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Rear Camera Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Rear Camera Replacement: stap 9, afbeelding 1 van 2 Sharp Aquos Crystal Rear Camera Replacement: stap 9, afbeelding 2 van 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Rear Camera Replacement: stap 10, afbeelding 1 van 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Rear Camera Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Rear Camera Replacement, Rear Camera: stap 12, afbeelding 1 van 2 Sharp Aquos Crystal Rear Camera Replacement, Rear Camera: stap 12, afbeelding 2 van 2
    • Disconnect the camera from the board using a plastic opening tool.
    • Remove the camera from the back of the circuit board.
Conclusie
Felicia Imbriano
1.248 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 7-4, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 1,499
