Ga door naar hoofdinhoud
Sharp Aquos Crystal Digitizer Replacement
Wat je nodig hebt
  1. Sharp Aquos Crystal Digitizer Replacement, Back Panel: stap 1, afbeelding 1 van 3 Sharp Aquos Crystal Digitizer Replacement, Back Panel: stap 1, afbeelding 2 van 3 Sharp Aquos Crystal Digitizer Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Digitizer Replacement, USB Port: stap 2, afbeelding 1 van 2 Sharp Aquos Crystal Digitizer Replacement, USB Port: stap 2, afbeelding 2 van 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Digitizer Replacement: stap 3, afbeelding 1 van 2 Sharp Aquos Crystal Digitizer Replacement: stap 3, afbeelding 2 van 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Digitizer Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos Crystal Digitizer Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Digitizer Replacement: stap 5, afbeelding 1 van 3 Sharp Aquos Crystal Digitizer Replacement: stap 5, afbeelding 2 van 3 Sharp Aquos Crystal Digitizer Replacement: stap 5, afbeelding 3 van 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Digitizer Replacement: stap 6, afbeelding 1 van 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Digitizer Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Digitizer Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Digitizer Replacement: stap 9, afbeelding 1 van 2 Sharp Aquos Crystal Digitizer Replacement: stap 9, afbeelding 2 van 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Digitizer Replacement: stap 10, afbeelding 1 van 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Digitizer Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Digitizer Replacement, Battery: stap 12, afbeelding 1 van 1
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Digitizer Replacement: stap 13, afbeelding 1 van 2 Sharp Aquos Crystal Digitizer Replacement: stap 13, afbeelding 2 van 2
    • Lift the battery out with your hands.
  14. Sharp Aquos Crystal Digitizer Replacement, Screen: stap 14, afbeelding 1 van 1
    • Replace this component with the new one.
Conclusie
Felicia Imbriano
1.248 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 7-4, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 1,999
