Inleiding
If your Shark Vertex Pro IZ682H vacuum is having issues with its filter, use this guide to learn how to clean and/or replace it. When a vacuum has had a lot of usage, the filter tends to get clogged or damaged and needs to be fixed in order for the vacuum to function properly. By following this guide, you can learn how to thoroughly clean the filter, or replace it if it is damaged.
Wat je nodig hebt
On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
On the body of the device you will find there is a large grey button on the side of the dust cup.
Pressing this button will release the dust cup from the body of the device.
Empty the dust cup if the device has already been in use.
You will find the post-motor filter in the device under where the dust cup was.
The post-motor filter can be easily removed now.
Clean the filter with soap and water.
