Ga door naar hoofdinhoud
Shark Vertex Pro IZ682H Post-Motor Filter Replacement
Wat je nodig hebt
  1. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Battery: stap 1, afbeelding 1 van 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: stap 2, afbeelding 1 van 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: stap 3, afbeelding 1 van 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Pre-Motor Filter: stap 3, afbeelding 2 van 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Post-Motor Filter Replacement: stap 4, afbeelding 1 van 2 Shark Vertex Pro IZ682H Post-Motor Filter Replacement: stap 4, afbeelding 2 van 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
  5. Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: stap 5, afbeelding 1 van 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: stap 5, afbeelding 2 van 3 Shark Vertex Pro IZ682H Post-Motor Filter Replacement, Post-Motor Filter: stap 5, afbeelding 3 van 3
    • You will find the post-motor filter in the device under where the dust cup was.
    • The post-motor filter can be easily removed now.
    • Clean the filter with soap and water.
    • Examine your filter for any damage, and if you find any you can buy a replacement on the Shark website.
Conclusie
Tyree Brooks
486 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 49
Altijd: 1,108
