Ga door naar hoofdinhoud
Shark Vertex Pro IZ682H Brush Roller Belt Replacement
Wat je nodig hebt
  1. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller: stap 1, afbeelding 1 van 1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab to the direction where the arrow is facing.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
  2. Shark Vertex Pro IZ682H Brush Roller Belt Replacement, Brush Roller Belt: stap 2, afbeelding 1 van 1
    • Turn the three plastic locks to the unlocked position and remove the crevice tool.
    • Use T9 and T15 screwdrivers to remove the seven screws.
  3. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: stap 3, afbeelding 1 van 2 Shark Vertex Pro IZ682H Brush Roller Belt Replacement: stap 3, afbeelding 2 van 2
    • Use an opening tool on the edges of the casing and pull off the thin plastic coverings on both sides.
    • Expect to hear snapping noises.
    • Pull the plastic coverings off the powerhead.
  4. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: stap 4, afbeelding 1 van 1
    • Remove the six screws using a T15 Torx security screwdriver.
    • Remove the plastic headcover.
  5. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: stap 5, afbeelding 1 van 1
    • Remove the seven screws using the T10 and T15 Torx security screwdriver.
    • Lift the covering and motor assembly enough to see the belt.
  6. Shark Vertex Pro IZ682H Brush Roller Belt Replacement: stap 6, afbeelding 1 van 1
    • Remove the belt and power nozzle.
    • When reinstalling, be sure the belt is tightly secured around the gear grooves.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyree Brooks
486 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Leden
2 opmerkingen
Thanks for the instruction. It helped, however, I cannot find the brush anywhere that goes to this vacuum (the one that attaches to the belt)
Eric - Antwoord
Hey I am looking for the brush. Did you manage to find it or find an alternative?
John Melo -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 236
Altijd: 6,385
