Ga door naar hoofdinhoud
Shark Ultimate Professional Reservoir Replacement
Wat je nodig hebt
  1. Shark Ultimate Professional Reservoir  Replacement, Reservoir: stap 1, afbeelding 1 van 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: stap 1, afbeelding 2 van 3 Shark Ultimate Professional Reservoir  Replacement, Reservoir: stap 1, afbeelding 3 van 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
  2. Shark Ultimate Professional Reservoir  Replacement: stap 2, afbeelding 1 van 2 Shark Ultimate Professional Reservoir  Replacement: stap 2, afbeelding 2 van 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Reservoir  Replacement: stap 3, afbeelding 1 van 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
  4. Shark Ultimate Professional Reservoir  Replacement: stap 4, afbeelding 1 van 3 Shark Ultimate Professional Reservoir  Replacement: stap 4, afbeelding 2 van 3 Shark Ultimate Professional Reservoir  Replacement: stap 4, afbeelding 3 van 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Reservoir  Replacement: stap 5, afbeelding 1 van 2 Shark Ultimate Professional Reservoir  Replacement: stap 5, afbeelding 2 van 2
    • Remove two screws (left and right) affixed to circuit board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Drew Carff
868 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Fall 2017 Lid van USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Leden
10 handleidingen geschreven
3 opmerkingen
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
primrose33166 - Antwoord
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Dalmacca-Hame - Antwoord
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
Muhammad Ahmad - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 2,148
