Ga door naar hoofdinhoud
Shark Ultimate Professional Mode Display Replacement
Wat je nodig hebt
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: stap 1, afbeelding 1 van 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: stap 1, afbeelding 2 van 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: stap 1, afbeelding 3 van 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: stap 2, afbeelding 1 van 2 Shark Ultimate Professional Mode Display Replacement: stap 2, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: stap 3, afbeelding 1 van 3 Shark Ultimate Professional Mode Display Replacement: stap 3, afbeelding 2 van 3 Shark Ultimate Professional Mode Display Replacement: stap 3, afbeelding 3 van 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: stap 4, afbeelding 1 van 3 Shark Ultimate Professional Mode Display Replacement: stap 4, afbeelding 2 van 3 Shark Ultimate Professional Mode Display Replacement: stap 4, afbeelding 3 van 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: stap 5, afbeelding 1 van 2 Shark Ultimate Professional Mode Display Replacement: stap 5, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: stap 6, afbeelding 1 van 2 Shark Ultimate Professional Mode Display Replacement: stap 6, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: stap 7, afbeelding 1 van 3 Shark Ultimate Professional Mode Display Replacement: stap 7, afbeelding 2 van 3 Shark Ultimate Professional Mode Display Replacement: stap 7, afbeelding 3 van 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Drew Carff
868 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Fall 2017 Lid van USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 646
