Ga door naar hoofdinhoud
Shark Ultimate Professional Circuit Board Replacement
Wat je nodig hebt
  1. Shark Ultimate Professional Circuit Board Replacement, Circuit Board: stap 1, afbeelding 1 van 3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: stap 1, afbeelding 2 van 3 Shark Ultimate Professional Circuit Board Replacement, Circuit Board: stap 1, afbeelding 3 van 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Circuit Board Replacement: stap 2, afbeelding 1 van 2 Shark Ultimate Professional Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Pull the split end of the power cord upward through the ball joint.
    • Set aside the power cord.
  4. Shark Ultimate Professional Circuit Board Replacement: stap 4, afbeelding 1 van 3 Shark Ultimate Professional Circuit Board Replacement: stap 4, afbeelding 2 van 3 Shark Ultimate Professional Circuit Board Replacement: stap 4, afbeelding 3 van 3
    • Use the Philips head #0 screwdriver to remove the remaining 6.58mm screws that hold the wires on the bottom (brown and blue).
    • Remove from left to right
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
  5. Shark Ultimate Professional Circuit Board Replacement: stap 5, afbeelding 1 van 2 Shark Ultimate Professional Circuit Board Replacement: stap 5, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove the two 9.75mm screws (left and right) affixed to the circuit board.
  6. Shark Ultimate Professional Circuit Board Replacement: stap 6, afbeelding 1 van 2 Shark Ultimate Professional Circuit Board Replacement: stap 6, afbeelding 2 van 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Gently pull the circuit board from affixed position.
    • The circuit board will not be completely separated at this point.
  7. Shark Ultimate Professional Circuit Board Replacement: stap 7, afbeelding 1 van 3 Shark Ultimate Professional Circuit Board Replacement: stap 7, afbeelding 2 van 3 Shark Ultimate Professional Circuit Board Replacement: stap 7, afbeelding 3 van 3
    • Remove the mode display piece and set aside.
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
  8. Shark Ultimate Professional Circuit Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the connecting wire from the connected adapter in the handle by pulling lightly.
    • Set aside the circuit board.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Drew Carff
868 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Fall 2017 Lid van USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Leden
10 handleidingen geschreven
4 opmerkingen
My shark 1505C does not have philips screws on the back. They are security torx and I cannot find a tool to open it.
Where can I buy a main board for this iron ?
Thanks
NevG.
nevstarg - Antwoord
where do I buy it's circuit board?
egovieira - Antwoord
Where can u buy the circuit board professional 1800 version?
Astinder Singhera - Antwoord
How much does the circuit board cost? and where can i purchase it?
D.A. Willis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 47
Altijd: 3,177
