Ga door naar hoofdinhoud
Shark Steam Pocket Mop Steam Head Hose Replacement
Wat je nodig hebt
  1. Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: stap 1, afbeelding 1 van 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: stap 1, afbeelding 2 van 3 Shark Steam Pocket Mop Steam Head Hose Replacement, Steam Head Hose: stap 1, afbeelding 3 van 3
    • Start by removing this quarter inch Phillips head screw
    • Next remove the two 1/8th inch Phillips head screws at the bottom of the connector piece.
    • Next remove the nine 1/8th inch Phillips head screws along the base of the steam head connection.
    • Next remove the two 1/8th inch Phillips head screws along the base of the steam head connector.
  2. Shark Steam Pocket Mop Steam Head Hose Replacement: stap 2, afbeelding 1 van 3 Shark Steam Pocket Mop Steam Head Hose Replacement: stap 2, afbeelding 2 van 3 Shark Steam Pocket Mop Steam Head Hose Replacement: stap 2, afbeelding 3 van 3
    • Once all the screws are removed and the baseplate of the steam head connection has been placed aside, gently remove the connector from the bottom of the base.
    • Gently remove the end caps of the hinge piece of the connector piece with your fingers.
    • Gently remove the host connection from the back plate.
  3. Shark Steam Pocket Mop Steam Head Hose Replacement: stap 3, afbeelding 1 van 2 Shark Steam Pocket Mop Steam Head Hose Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use your tweezers to remove the metal ring holding the hose to the plastic end piece and replace the hose / bit as needed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Howe
549 Reputatie
5 handleidingen geschreven
USF Tampa, Team S13-G7, Cagle Fall 2017 Lid van USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Leden
10 handleidingen geschreven
2 opmerkingen
Ok, but where do I get a replacement hose?
semajrolyat - Antwoord
Same question as semajrolyat: where to source replacement hose?
CLIFTON CHANG - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,951
