Ga door naar hoofdinhoud
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement
Wat je nodig hebt
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: stap 1, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: stap 1, afbeelding 2 van 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 2, afbeelding 1 van 1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 3, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 3, afbeelding 2 van 2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 4, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 4, afbeelding 2 van 2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 5, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 5, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 5, afbeelding 3 van 3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 6, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 6, afbeelding 2 van 2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 7, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 7, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 7, afbeelding 3 van 3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 8, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 8, afbeelding 2 van 2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 9, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 9, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 9, afbeelding 3 van 3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 10, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 10, afbeelding 2 van 2
    • Wiggle the brush roller upwards from the left and right side slots.
  11. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush Belt: stap 11, afbeelding 1 van 1
    • Remove the roller brush by sliding it out toward the left, off the belt.
  12. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: stap 12, afbeelding 1 van 1
    • Remove the belt from the motor gear by sliding the belt away from the gear and belt motor.
    • In the following picture the belt was already removed.
Conclusie
Daniel Ceja
277 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G3, White Winter 2019 Lid van Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 563
