Ga door naar hoofdinhoud
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
Wat je nodig hebt
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: stap 1, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: stap 1, afbeelding 2 van 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 2, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 2, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 3, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 3, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 3, afbeelding 3 van 3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 4, afbeelding 1 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 4, afbeelding 2 van 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: stap 4, afbeelding 3 van 3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua Morrison
196 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G3, White Winter 2019 Lid van Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Leden
12 handleidingen geschreven
Één opmerking
What is the motor PN and where can I get one?
Dennis Meece - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 1,459
