Ga door naar hoofdinhoud
Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement
  1. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: stap 1, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement, HEPA Filter: stap 1, afbeelding 2 van 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: stap 2, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: stap 2, afbeelding 2 van 2
    • Remove the red cover from the front of the vacuum by pulling the latch found at the bottom of the cover forward and moving the whole cover downward.
  3. Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: stap 3, afbeelding 1 van 2 Shark Rotator Slim-Light Lift-Away Upright HEPA Filter Replacement: stap 3, afbeelding 2 van 2
    • Remove the filter by pulling it straight out.
    • To clean the filter, rinse it under water and allow it to dry before placing it back in the vacuum.
Conclusie
Carson Craft
251 Reputatie
1 Handleiding geschreven
Cal Poly, Team S19-G3, White Winter 2019 Lid van Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 364
