Inleiding
The roller brush can have debris that will cause the vacuum to not work properly. It is important that you always clean your roller brush after every use, so that your Shark Rotator Powered Lift Away Speed Vacuum can perform at it's best. This guide will show you how to change your roller brush if it becomes damaged or is broken.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Turn the vacuum on its side.
Using a quarter, twist the three green locks to the unlock position.
Pull the bottom roller brush cover to open the vacuum.
6 andere personen hebben deze handleiding voltooid.
7 Opmerkingen
Exactly, I struggled for sometime trying to find that 1 little screw that was a Phillips head.
I figured out how to get it apart… Where do I find a new roller?
This is already out of date. While this was the best guide I could find online, my model is just a tad newer. And much more of a PITA. Now a T20 “tamper proof” is needed, the one with the little indentation. And they’ve added more to make the process even less user friendly. One tiny screw at the base of the outlet to the tube, and another tiny screw positioned halfway under the clip to remove the plate. AND I had to remove pins from the hinges. We won’t buy a Shark again.
