Ga door naar hoofdinhoud
Shark Rotator Powered Lift-Away Speed Headlight Replacement
Wat je nodig hebt
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: stap 1, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: stap 1, afbeelding 2 van 2
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 2, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 2, afbeelding 2 van 2
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 3, afbeelding 1 van 1
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 4, afbeelding 1 van 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 4, afbeelding 2 van 2
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 5, afbeelding 1 van 1
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 6, afbeelding 1 van 1
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 7, afbeelding 1 van 1
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 8, afbeelding 1 van 1
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 9, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 9, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 9, afbeelding 3 van 3
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 10, afbeelding 1 van 1
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 11, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 11, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 11, afbeelding 3 van 3
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 12, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 12, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 12, afbeelding 3 van 3
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 13, afbeelding 1 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 13, afbeelding 2 van 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: stap 13, afbeelding 3 van 3
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
Conclusie
Dakota Rodriguez-Ransom
605 Reputatie
2 handleidingen geschreven
Cal Poly, Team S4-G6, White Fall 2018 Lid van Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 18
Altijd: 2,006
